Simple seat lever question
(In Topic #232325)
Was going to order some new seat lever trims for my 92 cab to replace my existing broken ones when I realised I could not find any info on how to remove the actual tilt lever to fit them. I dont want to just start pulling at it without any confirmation from anyone who has done it. If it's too risky a job and may cause damage I can certainly live with it lol
1991 Mk1 Golf GTi Rivage 1.8cc
113k on the clock
Owned for 16 years
113k on the clock
Owned for 16 years
Remove the Screw as yours is a 90ish cabby and they have the lower screw and a cover to hide the screw.
Grab the lever and pull. Be sure that you have the clip on the inside or it may have stayed on the lever.
You can use a small flat blade and pry the thing off using the seat frame to hold the blade.
yes matey you just pull them off.... not sure if thats right style , but same applies pull it off. then remove cover.
On the drive
Myvalver 89 GTi Grey mk2 16v
Thanks lads
113k on the clock
Owned for 16 years
113k on the clock
Owned for 16 years
