Ring Lights as Indicators
(In Topic #217077)
Hi everyone might sound a bit silly but I’m looking to use 2 ring reverse lights as indicators on the front of my car as I’m going for the no bumper look, is it possible to cut the wire from existing indicators to wire the ring lights up or do I have to do it another way??
Many thanks
Many thanks
Avoid cutting the wire if possible.
If you follow the indicator wires back into the engine bay you'll find that there is a connector block.
If you pull the two connectors apart you can then run spades from the connector block to your new indicators without chopping original wires.
Have you thought about LED indicators from a motorbike? They've what I've used.
Ian
Ian
I was thinking of using the old indicator wire leaving the connector on which is connected to the existing connector and wiring it up from the end where it connects to the bulb if you get what I mean? I only bought these ones because I want them to fill the holes where the bumper would usually go
What age is your car ? Because I’m in the process of doing something similar for my cabby and have found oem connectors to plug into the existing loom so no need to cut up any thing, let me know if you want any part numbers
Sent from my iPhone using Tapatalk Pro
1992 1.8 8 valve Convertible GTI
2008 E93 335i N54 Twin Turbo
3 Kids
Suzuki LT50 Quad
( and the Mrs )
3 Kids
Suzuki LT50 Quad
( and the Mrs )
These are my original ones
3 Kids
Suzuki LT50 Quad
( and the Mrs )
3 Kids
Suzuki LT50 Quad
( and the Mrs )
It’s 1992 I have spare connectors I purchased them from VW but I don’t know which cable I need that’s why I was think cut the old indicators at the bulb to keep the original connectors then fit 2 female spade connectors into the ring light
Mine are different to them mate
What you don’t know which plug or actually what wire to make your new cables from ?
3 Kids
Suzuki LT50 Quad
( and the Mrs )
3 Kids
Suzuki LT50 Quad
( and the Mrs )
I’m thinking of cutting where I’ve marked and putting spade connectors onto it which will the. Connect to my ring light if you get what I mean? Then I’ve still got the original connector at one end
You can slip a small screwdriver inside your original connectors to get the plastic off and they’re just spade terminals inside so you can just make up a new length. But your way will work just as well as long as the length is there. Either way I’m sure will be fine. Just encase you’re going to use LED bulbs as I did you have to put a resistor in line or they flash like mad lol
3 Kids
Suzuki LT50 Quad
( and the Mrs )
3 Kids
Suzuki LT50 Quad
( and the Mrs )
