Blank switch and surround
(In Topic #237526)
I need to find or new blank switch to go above fog and hazard light and I want the surround that goes around hazard light, rear demister etc.
I have attached photos. Does anyone know part numbers or have items?
I want to replace top aftermarket switch with a blank and get the surround for all the 4 switches. UK model 1982
I may have those laying about I can check for you at the weekend if you haven’t already sourced them by then
Your switches are also in the wrong place/order, picture here for reference.
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=how-to_2%2Fhow-to-remove
I used a regular slim line rocker but cut the blank and retrofitted it.
Installing a AC compressor Cut-out Switch | Volkswagen Owners Club Forum
Now take one of the blanks out of your dash Carefully using a hack saw, saw the raised portion off , this will open a hole in the plate to allow the switch to
be inserted. This is a custom fit and filing will need to be done.
That would be great. The missing surround and aftermarket switch that can be blanked would really improve the look when driving.
