Automatic Speedo cable
(In Topic #233093)
Steve1973 said
Hi folks, looking for advice from anyone with an automatic. The car is a 1.8 carburettor engine with auto box 1989. Looking for a new Speedo cable, part 172957803N which are like hens teeth. I can get a Mk2 cable, part 192957803c which looks the same but is 400mm longer. Has anyone fitted this cable? Was it the Same, just longer? Any issues?Cheers Steve.
Hi Steve
I've had the same issue with my mk1 auto and have used the 1600mm long mk2 cable which is identical but just longer..routes fine but ive brought it over the top of the air cleaner…yet to test but i think it shoud be fine..can post some photos if that helps?…got it from vw heritage
Steve1973 said
Hey Boffin, Thanks for the reply. That's exactly the information I was looking for Thanks. I went down another route that didn't work out. I used a company called speedy cables (which I would not recommend). They made it completely wrong and was a £40 mistake. I will look into getting the Mk2 cable as I originally was going to do. Thanks again, Steve.
Hey Steve
no problem, would the vw heritage part number and some photos help?
regards
Adam
BTW..the reason i changed mine was the previous owner had snapped the securing clip off the plastic at the speedo end and it wouldn't stay on!
Most folks over here just used the 90's single cable that screwed on at the tranny and clipped on the back of the speedo.
I know that my speedo LHD cable over wrapped the brake res cap, and any time that I looked at it funny, or moved it ever so gently to clear the brake res cap the thing would disconnect from the rear of the speedo housing.
Steve1973 said
As long as you are not putting yourself out, photos and part number would be nice. Thanks again.
No probs, will drop some on later when back..heres the VW heritage link for the cable i used;
https://www.heritagepartscentre.com/uk/192957803c-speedometer-cable-for-right-hand-drive-with-automatic-gearbox.html
Note that the last one shows the cable going between heater pipes..thats how the original one was routed..not sure if thats correct!
Steve1973 said
Thank you all for the replies and information. Thank you Adam for the photos they are very helpful. Thanks to Brian for your knowledge. I think I can confidently buy that Mk2 cable and know it will fit 😀
Thanks Steve!
we are all on here as fellow enthusiasts to help, advise and share our knowledge to keep these great old VW's going!
feel free to ask if you need any more info!
adam
