89 clipper won't start
(In Topic #221101)
AA mechanic didn't get her going and she was towed home.
Any ideas where to start? Fuel pump? Fuses?
Thanks in advance.
Regional Host NE
the inlet see if it trys to start
Remove the fuel pipe going into the filter and blow down it back into the fuel tank, you should be able to do it with your mouth and hear bubbles in the fuel tank, refit the fuel pipe and give it a try….
Regional Host NE
inlet stops all the is it this is it
that you just want the car to
at least try to start this is not
rocket science induction
compression ignition exhaust
basics
I really appreciate these comments to guide us.
Regional Host NE
i would not think it has
Regional Host NE
to start on that anything
volatile
Regional Host NE
engine
https://www.ebay.co.uk/itm/VW-GOLF-JETTA-MK1-MK2-1-6-1-8-CABRIOLET-CARB-ENGINE-FUEL-PUMP-C435/202596988335?hash=item2f2bb8b5af:g:j4IAAOSwOylcZWT6
Unless someone has fitted an aftermarket electric fuel pump….
To test the mechanical fuel pump you will need to un bolt it from the engine block and remove the fuel lines, move the lever on the back up and down and hold your thumb over the outlet, you should feel some pressure from the pump. You can then attach the inlet fuel line and pump the fuel fuel pump to see if petrol will come out of the outlet but be careful of petrol spraying out so have a rag to hand.
If unsure what's fitted to your engine post up a picture then we can see what's there.
Regional Host NE
did not have this problem take this
off do this do that it is a basic engine
