fuel guage sender
(In Topic #82601)
fuel guage sender
Hello,
Tried taking this off the other day but it wouldn't budge, anyone know how its ment to come off??
thanks
thanks
I'm now mk1less, ahhhhhhh!
Gone but not forgotten;
'83 Schwarze black GTi
'83 Lhasa green GTi
'80 Indiana Red Met. GLS
'83 Lhasa green GTi
oh right, so just i little bit of brutt force then, cheers!!
'83 Lhasa green GTi
'83 Lhasa green GTi
Old screwdriver wedged into one of the slots and some gentle persuasion with a hammer usually does it for me...
…Use an old bit of wood (hammer handle or similar) just in case any fuel vapour is around, particularly if the 'O' ring is damaged…..
Check the condition of the 'O' ring, replace if there is the slightest doubt about it (cheap from VAG or GSF), make sure the surfaces are clean and put a LITTLE bit of grease on the ring when replacing it….
I put on an old 'O' ring once and was plagued by fumes and a leaking tank till I renewed it…!!!!
You may have a lift pump attached (as shown below) if it's a GTI cabby….the 'O' ring is arrowed here….
yes i have an 83' GTi so it won't have a lift pump, i'll give it a go later on, cheers for the replies!!
'83 Lhasa green GTi
'83 Lhasa green GTi
