all you 1600 GTI chaps - Fuel pump priming??
(In Topic #79089)
it seems that the 1800 GTI fuel pump primes for 3 seconds when the ignition is switched on, but my 1600 doesn't do this :?
I know the fuel pump is good is it's new, but would like to know from other 1600 owners if your fuel pump primes when you turn the ignition on?
or if this is a difference between the early and late series 2 electrics (although Crazyquiff's Cabby doesn't prime either which would suggest this isn't the case)
1983 1100 C
1983 1100 C
I replaced the check valve that's in front of the pump (which was broken) so just need to check the pressure again.. hasn't fixed the hot starting though so on to more expensive parts now by the look of it :cry:
1983 lhasa green GTI
1982 lemon yellow CL
