Power supply to front wiper motor
(In Topic #81347)
Which lead supplies 12v to the front windscreen wiper motor? Cany anyone confirm which wire should get 12v? None of the wires coming up to the motor get 12v on mine at the mo…
Looking at the wiring diagram in the Haynes manual it should be no. 31, which on my car corresponds to the black and grey wire. However, there's no voltage on it at all.
I've replaced the relay and the motor, and the fuse is defintiely ok, so I think it could be a problem with the wiring.
Thanks in advance
Rich
Thanks in advance
Rich
Can anyone help?
It's in a good cause - if you help me I can make it to Ed38!
Any thoughts would be very much appreciated
Rich
Rich
Here's the wiring on the windscreen wiper stalk on the steering column - does this look right?
Rich
Rich
I think its the green wire or else its yellow and green i will check it out tommorow and let you know
1983 VW golf mk1 1.6 dsl.
1987 VW caddy mk1 1.6 dsl.
1986 VW caddy mk1 1.6 dsl.
1989 Jaguar sovereign 3.6 auto
1978 Mini clubman 998cc
1972 Mini 850cc
1989 volvo 340gl 1.7- sold
1989 Mitsubishi shogun 2.5 tdi
1972 Mini 850cc
Brilliant - thanks
I checked it out today and the green & yellow wire,
the green wire, and the green & black wire get 12v
when the brown wire and the black & grey wire are
plugged in.
GREEN WIRE - speed 1 + spray and wipe
GREEN & YELLOW - speed 2
Im not to sure what the green & black wire is for but it might be for the intermittent wipe
I hope this helps. :wink:
plugged in.
1972 Mini 850cc
1972 Mini 850cc
Thanks again - I fixed it in the end, by……………… changing the fuse! Couldn't believe it was that simple, but there we go…
For future reference I discovered that the black and grey has 12v on it permanently, which is switched by the indicator stalk to the relevant green + <other colour> wire to give the right speed.
Rich
Rich
was going to say check fuse and wiper elay i have a bad connection on my relay needs a nudge evry now and again
1983 mars red 1800GTi on ATS cups
G60'd, schrick cam, chipped, 70mm pulley, pace charge cooler, rolling road 182bhp 250Nm of torque, 14.50 quarter mile.
