Where is the water coming from...
(In Topic #72529)
![trevVW in the usergroup ‘Newbie’ trevVW in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
I was hoping someone could spread some light on a problem I am having with a lovely Mk1 Golf GTi, after it has rained there is a LOT of water in the drivers footwell and the rear driverside footwell. Also the hatch appears to be filling with water, as I lift the boot you can hear water running down. I have had a scour around on the web and numerous things have been suggested such as the weather seals in the water, but I would really value any input from people who have experienced this matter.
It has a non factory sunroof, which I will check out fully tonight, at the moment I am trying to dry it out then I can sit in it next time it rains and see where any drips are coming from, any input????
Cheers guys…
T
Cheers guys…
T
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/20160605_084816191_iOS.jpg)
![Hairyarse in the usergroup ‘Moderators’ Hairyarse in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![Hairyarse in the usergroup ‘Paid Member’ Hairyarse in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Hairyarse in the usergroup ‘Regional Hosts’ Hairyarse in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![Hairyarse in the usergroup ‘Local hero’ Hairyarse in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Aside from you sunroof and things like the door and window seals, check your scuttle area under the bonnet and each side there are drain tubes. These can often (and quickly!) fill up with debry - leaves n stuff - and the water cannot drain away. If this happens it will overlflow through the heater fan and into your footwell (happened on drivers side with mine)
Easy fix, just unblock the rubber tubes!
![turbtechnicsMK1 in the usergroup ‘Old timer’ turbtechnicsMK1 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Also in the scuttle area, check where the wiper mounting brcket is welded to the scuttle as again you can get a small hole form between the bracket and the bulkhead/scuttle, or if your really unlucky a split between the two bracket mounts and this leaks water directly into the drivers side . Bets way to check this is to take of the plastic scuttle cover, clean out any muck and have a good prod about. (Seen this on mine, and spent months looking for leaks
ops: )
![:o](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/shocked.png)
![Avatar](https://img.photobucket.com/albums/v502/dubboy/76%20GTI/Driveravatar2.jpg)
Life Member
![dubboy in the usergroup ‘Local hero’ dubboy in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
![dubboy in the usergroup ‘Moderators’ dubboy in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![dubboy in the usergroup ‘Paid Member’ dubboy in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
Been mentioned before, but you could try covering the complete floorpan and footwells in talcum power, then sit inside with a helper and a hosepipe. Should help trace it.
Water in the tailgate is often the sealing of the rubber tubing between tailgate/body or the grommets for the heated rear window.
Rajan
Rajan
![Elfboi7 in the usergroup ‘Local’ Elfboi7 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
I have a similar problem from abve the steering ruber seal water drips into the footwell of the drivers side do you know where this could be coming from? The draining area is free of leavs etc, can water appear in this place from the front screen if there is rust around the common area?
Mark 1 Golf GTI 1982 1.6 owner!
Mark 2 Golf GTI 1986 owner!
![mcscrew in the usergroup ‘Local hero’ mcscrew in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Double check that your rear light clusters are tightly bolted down - it's surprising how far the water can track through the car.
HTH
Rich
HTH
Rich
![richiemk1gti in the usergroup ‘Regular’ richiemk1gti in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
i lwould do the same as other posts and if it has being doing it for while not only dry the carpits the sound deadening could be damp and very smelly!
I dont think its from the rear its just the front drivers side and i have striped the car clear of carpets and seats as there is alot of rust. any ideas?
![Timski in the usergroup ‘Old timer’ Timski in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
I`v just done a repair where this was happening and it was where the lower window frame had rotted out and was dripping down into the footwell.
![:(](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/sad.png)
keep on keeping on
