Is it a mk1 or 2
(In Topic #158248)
Just got my hands on a 1985 cabby, 1.6
the engine code is an EW and I am looking at replacing the ht leads, plugs, dizzy cap etc.
As far as I know 1985 was bang on change over from mk1 to mk2 with the tin tops, did the oily bits of cabriolets change to mk2 equipment too?
looking on vag codes it is down as a '83-'92 golf so I assume I am looking for mk2 leads/any future bits I look to replace that is engine related, is that correct?
Any help would be much appreciated.
Thanks.
1985 Cabriolet GL
MK2 came along in 1984 - you'll get the odd MK1 tintop from '84 but they're rare.
There was no MK2 cabby, only MK1's then the next was MK3. All running gear stayed MK1 - can't recall if engine's ever switched to MK2 spec at all but mostly were 1.8 carb and injection versions, as per MK1
Hope that helps
Guest user
