1.6 Wont Start
(In Topic #177419)
1.6 mk2 golf motor in mk1 caddy.
We have now fitted a mk2 golf driver 1.6 motor with a weber 32/34 dtml.
We have fuel going to carb and a spark at the plugs but it will not start.
We even towed it around a big field for 10 mins and still nothingcf_emoticons__BangHead:The fuse box has a few relays missing as it had a diesel in before(would
this make a difference to it firing up??)
Any advise would be great Guys Also does the ignition timing have to be spot on to start?
Last edit: by darrenr
1983 mk1 golf gti campaign
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
if you've flooded it you wont get anywhere till you leave it long enough to dry out, remove the plugs and clean the tips if grotty, then just walk away from it for a few hours
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
