seat belt
(In Topic #111591)
seat belt
Cheers Nick.
The rears just bolt in, although you need to slot it through the parcel shelf supports.
Do you need to know where the mounting points are on the bodywork, to bolt them into? Or are missing the bolts and fittings?
spacer -> washer -> belt -> washer -> bolt -> cover cap
front 3door bottom:
big metal plate -> spacer -> washer -> belt -> washer -> bolt -> big spring
(the spring makes belt flip backwards so out of way for passengers getting in/out back)
front 5 door bottom:
spacer -> small washer -> big washer -> belt -> big washer -> bolt
rear top:
spacer -> support arm if included -> washer -> belt -> washer -> bolt -> cover cap
rear belts just bolted down at base, no washers or owt
