another electric problem :(
ill need to get a multimeter off my mate
cheers for the reminder ill do that tomorrow aswell
Your car amp is probably drawing about 300-400W based on what you've told me.
35A x 12V = 420W
45A x 12V = 540W
So you can see even when the alternator is performing at peak current levels it would only be providing a 100-200W of spare power, turn on the lights and/or heater and your battery will drain.
You need at least a 55A or I'd suggest going further and get a 65A, if you going to increase the stereo further, go for the 90A one.
And don't waste your time measuring Voltages it proves nothing
~Madferret
Mk1 1457cc 5door GX '83
hope this is what was drainiogn the battery
ill see after a good run if this has mad any differance
Jack1 said
there not writing on the altinator or any stickers so i carnt find out
Its a small block, not sure if you can upgrade anyway. So you might just have to settle with the power you have. Someone else is bound to know, etc.
But first……try to find out if the existing one is fault.y.
well im gunna do a engine swap cause this engine has started leaking oil pritty bad now
Jack1 said
ye rmna
rmna?
engine swap - like for like? Will the new one come with an alternator?
it was ment to say yer man
and na uprateing to a 1.6 16v engine from a mk4 polo
and im sure you need a polo altinator for it too
wont be for a while tho
I'm pretty sure I had a 65A on my 1.3 Driver, certainly wasn't a 35/45A anyway, but if as you say there's no easy upgrade the split charger system as you suggested is the best alternative. At least then if the amp battery dies the car will still function.
Fully working or not though a small alternator will cause problems with the amps.
~Madferret
