Oil pressure gauge wiring
(In Topic #107539)
Have a Smiths gauge with 0-100 LB/O", plastic tube which goes from the gauge to the t-peice I need..
cheers!
DubPartz
Cheers,
Meenrod
1991 Mk1 Golf GTI Cabriolet Sportline
Meenrod
Meenrod said
Why do you need a t-piece? Do you have the correct sender? Replace the one on the side of the block with a twin pole.
hi
the sender goes above the oil filter not the side of the block,you will find a t piece on ebay or a rally type website.is your senders 10mm x 1mm thread use these all in dollars but a uk site
http://www.demon-tweeks.co.uk/products/ProductDetail.asp?cls=ROAD&pcode=LMA050/M
cheers paul
I will get a pic up of the cable and gauge just to confirm 100% the part for the block will be right!
What thread size for the engine do I need?
Is it just M10X1.0 ?
Jon`s Dad
https://www.holden.co.uk/displayproducts.asp?sg=2&pgCode=070&sgName=Hardware&pgName=Gauges&agCode=0611&agName=Smiths+Classic+Gauge+Fittings
Does this go straight in to the t-peice on the block?
This picture below says I need an adaptor? I'm not 100% sure?! :dontknow:
https://www.holden.co.uk/displayproduct.asp?sg=2&pgCode=070&sgName=Hardware&pgName=Gauges&agCode=0611&agName=Smiths+Classic+Gauge+Fittings&pCode=070.252
Would I just need to screw the oil line in to the adaptor, then adaptor in to the t-peice?
T pieces and a single pole sender; or a double pole sender (the other one providing low oil pressure warning switch function, which is what the new sender would replace) is used with an electrical oil pressure gauge.
TBH I'd only recommend an electrical oil pressure gauge.
Might look at an electrical one then, I guess from the gauge to the sender is a wire with a connection to the sender?
Must be a bit dangerous having hot oil travelling through the pipe?
Early-1800 said
the ones with pipes leak and spray oil everywhere until theres none left in the sump.
Sorry, but that's just not true. I have been using mechanical gauges for over 30 years in all types of cars from race to street to show. Never have I had one leak, spray or drop oil into the car. Its just like everything else in this world, if you do it right then it works right. Even with the very slim chance that the tube could rub a hole into it or come loose from the fittings, the size of the tube is such that only a small amount of oil will be forced out. Unless you install the gauge with it right up in your face and take no care to route the tube, you would never have any problem if something were to fail. They are approved be all racing bodies that I can think of and are more accurate, my opinion, and reliable, also my opinion then electric ones.
Nice gauges btw - old skool cool 8)
I used to run mini's with smiths mechanical gauges and never had any problems at all.
Any idea on the pressure it should be at roughly?
Anyone got any ideas of ideal pressure?
