POSS WUR PROBLEM
(In Topic #106045)
POSS WUR PROBLEM
bytor said
Hang an - surely this is the right section for a question on the WUR??
It is now……….I moved it here from Chat area :mrgreen:
Ratty 83' 1100 Golf Now With 5 Speedsssssssss (Holly)
93' Polo Coupe ! .. Mates Project Car (Poppy)
70' Beach Buggy - Holier Than A Church !!! (Lilly)
72' Beetle in a thousand pieces (bro's) (Daisy)
The rubber hose from fuel pump to fuel lines has been attached using a circlip that doesn't quite grip it well enough. When you start the engine is runs fine (with fuel pissing out over the floor) but blipping the throttle causes starvation.
After a couple of mins at idle the leak stops and it runs sweet as a nut. Not sure whether that's pressure related that closes the leak.
Anyway, I'll be getting a smaller circlip but I suggest that you check to see whether you've got a similar leak somewhere as symptoms sound identical.
