A116 KLB - GTI Cabriolet Triple White
(In Topic #99545)
The start of topless fun
We have taken the plunge and have got ourselves a golf cabriolet!
Bought it today - not seen it yet! ( taking a gamble )
Here it is
Reg number is A116 KLB is it known to anyone on here?
Picking it up tomorrow - very excited!
Matt n Susie
Last edit: by mattn
a few hidden modern features like better brakes, alarm etc
but generally to get her looking as new as poss - apparently its got original seats with 50/50 split rears, they are all white - but the fabric is knackered! ( seems to have horizontal thin stripes on white material - any idea what these are? )
Matt
Hopefully you can give us good news after you pick it up
she is back wtih onely a few problems!
1 - she seems down on power 95 is top speed downhill and uphill feels like in too high a gear - any thoughts
2 - dash board is 30mph too fast - and top speed on dial is 120 - is that right? when lights are on, dashboard rev counter drops!
3 - ticks over a bit fast from when i had a rocco about 1200rpm ( if the gauge is right
thats all for now - if you can let me know any tit bits of info to help me out - please do.
thanks
matt
2. Speedo goes up to 120mph / Check earths
3. Adjust idle with screw on throttle body - should be around 800/900 rpm
Is it nice and sound with no rot?
little bit of rust under the windscreen
and a little bubble on door bottoms - but thats about it! ( shock )
got about 15 mots showing it doing 30,000 in the last 15 years!
the centre caps are missing from the wheels ( need some )
passenger side roof doesnt seem to clip in when down ( any thoughts )
will play with the plugs etc today and the earth for the dash
see if we cant get it running sweet!
matt
oh and got to love those nice long private roads hey :wink:
opened her up this morning, looked at dizzy, leads and plugs, not in the best of nick!
put back together - wont start! AHHHH
going to GSF to get some plugs, leads, dizzy and arm, fit them and see if that helps!
not sure what happened to the seats, the leather/vinyl is in great nick, just the bloody material thats gone, anyone know where i can get them fixed with original looking cloth?
Matt
<a><img></a><a href="Login to a private Photobucket.com album
Do it in stages. Check for a spark first. If no spark then check coil / ignition module / hall sender connections.
if yes check for fuel. If no fuel check fuel pump relay fuse / relay for operation.
anyhow - i have stripped the battery out cleaned up all the contact - followed the earth strap down and back - two bolts where it connects to the bodywork cleaned up the two bolts and spades and refitted, did the same for the earth strap to the rocker cover - are there any more?
stripped out the dash - seems there is some slight damage to the connector for the dash - bit of gaffa tape sorted - now the mfa and lights work as they should! ( still cant start car tho! ) ahhhh
dash surround a bit damaged - anyone got one?
Matt
Ordered some new hoses from my local stealer as i am leaking water from some perished hoses! ( not driving her dont worry! )
Sorted the dash - fingers crossed!
Stripped the clocks out and the wiring I could find, seems the blue on the back of the clocks is burned out in a few places, so I have had to "hot wire" some bits of it! ( but it works for now ! )
The rest of the car welll……
Took the passenger front arch off to look underneath - this is what I found…. not too bad I though
Now for the interior
Need some seats!
Managed to find the source of the problem of the roof not clipping down, a packet of sweets a babies bottle and a can of wd40 jammed in the mechanism!
I need a passengerside roof wind deflector ( i think that is what it is ) small bit of plastic where the roof joins the car at the hinge.
Thats all for now.
See you soon.
HTH
from the states but much better than the 25-40 quid you see them go for normally.
mate has bought from him in the past, shipping rates reasonable, take a long time to get here mind you.
http://cgi.ebay.com/eb…m=&item=320127577742&rd=1
1988 1.8 carb Golf Clipper
