Clipper tickover
(In Topic #89746)
Clipper tickover
Shes ticking over at around 1100rpm wnen fully warmed up so need to wind it down a bit.
Cheers all..
Carb adjustment
look at left hand side of the carb to the rear the large disc shaped object should have a nut on the back of it that will adjust idle speed. It's a tight squeeze but you can fit your hand behind and adjust with a small wrench/spanner.
Sorry I cant remember which way increases or decreases hope all this helps
I'd say be very careful as any adjustments can have a knock on effect on the carb.
Jamie
