wipers wont turn off!
(In Topic #79082)
is it run from a relay in the fuse box area? if so which one is it so i can check it.
any ideas what it could be?
Looks like it could be the self park switch in the motor . You no when you operate the intermittant wipe the wipers do one clean sweep then turn them selves off and go to the bottom of the screen ? Well if this fails they will stay on . The motor is supplied with a permanant live for this facility + it allows the wipers to self park at the base of the windsceen .
You may need to strip and clean the motor and the gear assembly . If its faulty a MK2 will provide a good replacement [search the forum for how] Furbers at Heapham has 2 in stock
Cheers Chudd………….
Regards Volkswarren
Big
thats one bit fixed but leads to the bigger question of where is the leak?? turns out the front window rubber wasnt sat right! job done, thanks all
