What C0 percentage and setting
(In Topic #78189)
Thnaks
Set timing first and fit new plugs,run engine until fan cuts in then set co.
the co screw is the one right next to the accelerator cable,at the back of the carb
Bert
what is the correct timing settings? if you don't mind
btw, i just changed the plugs, rotor arm, dizzy cap, air filter and really gave the engine a good clean out
Doing the oil tomorrow, i might flush it, do you reccomend flushing it? if so what's the best to use on this engine?
Thanks again
Deef
If you flush the engine use 50% paraffin mixed with 50% cheap 20w50 oil and let it fast idle about 1500rpm,dont drive it,let the engine run for 15 mins then drain it out straight away,renew filter and new oil
Works a treat on old fords and vauxhalls :wink:
B ok
bert
Will let you know how it goes!
Is the mixture screw the one with the flat head slot in it?
If so which is the idle speed screw,as i can't get down to 1% with out her stalling as the revs are dropping too low, so i need to up the idle speed first!
It damn tight in there though, I had to use the very short screw drivers
Is there anyhting else i need to do once i set the idle and C0 (aprt from the timming)?
Also on the other side of the carb, is a big screw, similar to the mixture screw, it's next the a start type charachter? what is this for?
Thanks again
Also the thermostat, is that located at the end of the bottom hose from the radiator up into the bottom of the water pump?
Thermostat is at the bottom of the water pump,2 10mm bolts and its out,dont lie underneath at the time :wink: you will get slightly damp..
If it runs crap after tuning it might be jetted different for high altitude in africa,my white citigolf was a gauteng registered car and had a reciept in the car showing high altitude jets fitted at a cost of 295 rand.
Bert
If iot is set for high altidtude, what's the best C0 setting?
At the moment when it returns to idle i get a pulsating air coming out of the exhaust and she sounds a bit like a beetle? Any ideas on that aswell?
Thanks gain, been a dimond!
Living in south wales - Swansea!
I got one last question for now!
I have to replace the temp gauge sender which i found is on the underside of the housing on the front of the block! - going to do this when i flush the system tomorrow!
what is the sender on the right hand side of the head for?
Fingers crossed, it stays nice tomorrow!
Take care
I wound the mixture screw in as far as i could with the idle at 950 before in was starting to cut out and it would not go any lower, i was constantly adjusting the mixture and then the idle screw to keep it at 950
any ideas?
