Fitting Alloys from a Corsa!!!
(In Topic #77491)
I always thought that Vauxhall wheels pretty much fit the VW's, the wheels I'm offered have a 56.5 centre bore whereas the mk1 is 57.1!
Will this mean the bolt is too large to go through the alloy to the hub? Or will there be just enough room?
Rich
Lhasa Green Mk1 GTI 1.8
having said that though, they may fit. theres some tolerance there so it may be closer than that. Its only 0.6mm to small anyway so sand in the hole 'may' get it large enough to squeeze on.
go on then post a pic of teh wheels :mrgreen:
They arent anything new or amazingly fresh or interesting. But they will improve the handling and give the car more of a wide look.
They are ET38! They should be okay……. I think!!!
Worry ye not
ET should be okay
DubPartz
Just bought it on sat.
Sorry about the size of the pic.
8O
Should have said they are currently fitted to a Corsa/came froma corsa.
Will the ET not work then??? :dontknow:
What size are the wheels you want to fit?
My Build Thread
Good point made mate.
The wheels are 15's, they come with 195/50 tyres.
Spacers themselves would only need to be 5 or 10mm maybe and are quite cheap.
The flipside however is that at 8" wide and 15 inch tall, you will probably end up having arch clearance issues and need to get your arches rolled :roll:
My Build Thread
Best bet is to whip the wheel off and try one b4 you buy them.
