1.8 16V conversion
(In Topic #77418)
1.8 16V conversion
83 Helios Blue shell/G60 build
83 1.8Gti Tintop doner car - SCRAPPED!
87 1.8GTi Quartet Cabby now on webbers all in red,daily driver
'90 Caddy Pickup
'83 1.5 Golf bare shell rebuild,knicked by pikeys for scrap
'90 Caddy Pickup
www.vwcaddy.com
did you get loom you needed in the end?
QuickChick, i've got a FAQ on the mk1 16V conversion, email me if you want it. It doesnt cover conversion from Deisel, its biased towards going from a GTI base, but there is a bit on converting carbed mk1 to inj wiring, may or may not be any use.
good luck
Good luck its like a jigsaw puzzle really. Are you using the 16v box, if so you will need cabrio driveshafts or late scirocco ones.
Mk1 Lahsa green, BBS RM, Mk1 Silver Campaign, Mk5 GT TDi, Audi A4 Avant S Line
mk1turbo said
I would say fuel pump and lines etc would be more of a problem really. You woud only really need the limited ecu wiring and unit that only runs throught the engine bay for a KR 16v 1.8. Oil pressure, water temp etc you have already have. If your doing a later 2.0 ltr then it s a different story.
scuse my ignorance, but does that mean that the basic engine wiring loom (exlcuding the TCI part) is the same on all the mk1 engines? (so aires for thermo switch, aux air valve, pressure sensors, temp sensors, starter motor, coil etc.
Sorry, have only had GTis ops:
