running bad
(In Topic #76741)
running bad
1983 1100 C
1983 1100 C
If you're buying secondhand parts, there is no real way of knowing its fine, unless you witness the car running previously with it!
budge said
do u know i can get a recon metering head from thx
Best bet is to get the one(s) that you have examined at your nearest Bosch Service Centre (see Yellow Pages), as it's more likely that it is out of adjustment for your car, rather than it's no good at all.
They can do all sorts of tests on the whole fuel injection system (system pressure, control pressure, warm-up regulator, air-bypass valve, etc) that even your average garage can't do because they don't have the correct gauges, etc.
