Newcomer with 1.6 karmann
(In Topic #76231)
cheers paul
Life Member
For the oil temp gauge you need to test you have 12V at the back of the gauge on the "+" terminal with the ignition on and 12V at the bulb with the lights on. Then you can trace back the wiring to see where the fault lies. You can use a multimeter or a test light for this.
For the mileage, does the speedo work correctly? If it does the speedo is to blame if it doesn't then I would check the cable connection at the back and at the gearbox end.
Rajan
