GX-restoration part 2 :-)
and engine bay is empty so i can work in now
cheers…….
Remember, VW made the last car in 1992. After that they started making vehicles.
MK1 GTI Campaign
MK2 GTI 8v
Imitation Magic Tree - 'Black Ice' smell
Plenty of rust
Embarrasing fuel problem
Porous cooling system!
MK2 GTI 8v
Plenty of rust
Great work by the way and the bay looks fresh too!
MK1 GTI Campaign
MK2 GTI 8v
Plenty of rust
MK2 GTI 8v
Plenty of rust
some photos of this.
:wink: cheers
sorry guys hi hi soon next photos but not much done becouse of stupid wether-my works mostly depend from that.as you know i have to cramped garage for body works. photos soon :wink:
i`m back hi hi.here some photos from my last works
soon more …. :wink:
What colour are you going to spray it when it's done?
Rich
Life Member
mcscrew said
Looking good, as always :y:
Rich
it will be sprayed in the same colour as it`s ( it was hi hi ) now it`s cleaned to original primer.will be painted with use DuPont 2 pack paint but not in this year i think next spring becouse i want go to Wolfsburg mk-1 meeting and car must be finished.i was on it first time in this year and i liked it very much so i can`t imagine not going there :y: it was realy great there.hope i can see you there someday :tlc:
pictures from my last work
painted with acid primer
wether starting to be not so nice last time but hopefuly floor from driver side is close to finish,some pics -welded floor
before
after
other works:
-with rear number plate lights(not finished grinding)
-engine mount repair
-and small repair panel-hand made ha ha
You car seems to have very similar rust to mine. As well the rear arch/trurret rust, the rust area on the left hand side floor to sill area looks identical :roll: . I have patched it for the mean time. Have to wait till next summer to rebuild the area accurately. Starting to loose the good weather here in the Uk as well, although I'm sure it gets a bt colder in Poland.
1983 1100 C
1983 1100 C
thanks for good opinions,from chudd too!
About welder-it`s just normal Mig-Mag .i`ll take a look what corect technical data it have if you need.This weld look so clean becouse from time to time i`m cleaning it with wire brusch for better contact.I`m useing to weld 0,8 wire size and bigger amperage-it give good penetration and resonably flat weld but you should be very careful becouse too long one weld can easyly make hole in tin body metal. one more-i`m useing 230v -i have only this in garage,two times burned main fuse ha ha ,better results are with 360v.
one more about wire-i used before 0,6 wire ,in my opinion it`s nothing wort,bad penetration even in bigger amperage and wire speed so changed for 0,8 -more risk of hole burning but time make from you master
chudd said
Nice job you are very skilled ……….
Well done mate
p.s love your shoes
Cheers……..
ha ha thanks-if you want i can ship to you a pair if you like them,ha ha
what size of foot you have ?…..ha ha
thanks for restoration coment..
cheers..
i`m back after long breake.here my engine restoration close to finish.
