New Wheel Help
(In Topic #74240)
New Wheel Help
fronts will be 7><14 and rears 8><14 with standard arches know the rear et will be a smaller number as theres more space there but does anyone know the best size ???
Tyre choice iam going for is 195 50 14 if i can find any any help appreciated thanks folks.
7x14 on the front is not too big at all and I would say ET 30 ish would be fine.
For the rears though 8 inches is quite wide, though with the 195's stretched on, you could probably get away with a similar offset of around ET 30.
My wheels are either ET 33 or 32 but are only 6 inch wide. The rears are nowhere near rubbing as the arches give quite a bit of clearance, though I think the fronts would be on the limit if it was any lower!
It's a tough call though and the best bet is to hope someone reads this post with a similar set up!!!
My Build Thread
paul
Yes its a golf,polos a matchbox car deffo wont fit that.
Prob comes from sump so low but useable at mo but gap between arch n tyre tooo BIG dry sump not an option so up the profile of tyre up to 50 from 45 and a smaller et on rear to fill arch more here look n see what i mean.
http://homepage.ntlworld.com/kevin.yeoman/WebGalleries/GTIFestival2005/GTI%20Festival%202005%20006.html
This is interesting - did you speak to the owner?
My Build Thread
