What shock?
(In Topic #73545)
What shock?
1983 1100 C
1983 1100 C
Aparrently there used to be a not so heavy duty one! Its discontinued now.
Cheers,
Ross
1983 1100 C
1983 1100 C
My struts look in good condition, so assume I could just change the inserts. Anyone recommend GSF or Euro Car Parts ones - also should they be oil or gas for 1100? Remember someone saying in that Golf C inserts are slightly smaller ends than other Mk1 ones - does anyone know about this?
1983 1100 C
1983 1100 C
Thanks for the
i am now conversant with URL'S and the like .I really should spend less time on the computer and more under the bonnet
Your shocks [thats the complete strut] according to my local Dealer are available next day part number v171 412 031 j [which is the same as the one you have] ?31.00 each + the vat . Might be worth asking again , part number same for all MK1 Golf's , guess must be South African specials still made in Germany mine had sticker manufactured Nov 2004 ..From experience all the inserts and struts are the same for all Golf's so buy the above and stick on the springs of your choice job done ?
Hope that helps ….
1983 1100 C
1983 1100 C
Chudd - nice one, noticed your tidy links in the last couple of days.
I've heard the heavy duty ones that are now the only ones available and that these are ok to use which was what I was going to do. However, dealer reckoned out of stock at the moment - might try ringing another dealer tommorow.
Regards the inserts, I understand there used to be two types - light weight for small block engines and heavy duty for big block. Problem is, I don't know if my existing struts are original light duty ones or heavy weight duty and therefore which insert to get if I go that route :dontknow: .
1983 1100 C
1983 1100 C
all inserts are the same size , they have to be as all struts are the same . If you look at say GSF they list inserts for all MK1 cars as the same it just depends what you want to spend and what you want in them eg Gas or Oil . The Important bit is the spring , fit heavy duty springs to a lightweight 1.1 and you will have a high riding rough riding car that looks like a 4x4 .
So fit what ever insert your happy with or replace the whole strut and find the right springs for your car and you should be well sorted [ oh and i rearly must get off this pc ]cheers Chudd ..
would look like a golf country.
Cheers Chudd, these people list a GTI and a non-GTI mk1 oil insert and a mk1 GTI insert (lists original VAG parts they replace when you click on them) which had been confusing me. Think I will go to GSF to keep things simple, cheers Nick.
1983 1100 C
1983 1100 C
I had to remove the two bolts at the bottom of the strut where it joins the wheel bering housing - of which the higher one adjusts the camber. I scribed up the position of the strut aginst the wheel bearing housing and marked the camber bolt. Got all scribes marks spot on when put it back toegther. Is this a reliable method of reatingin camber settings? Car seems to pull stright etc.
1983 1100 C
1983 1100 C
1983 1100 C
1983 1100 C
