Electric windows
(In Topic #72521)
Electric windows
I believe that the mk1 could be equiped with power windows (at least the cabrio?) but the scrap yards (here in sweden) does nt seem to have heaps of them .
So a simple way to fit pw with parts that are easily available would be greatly appreciated.
t.i.a
/Mike
-84 GTI Mars red (campaign)
-94 Audi S2 RS Avant
-98 VW Passat Variant TDI
I described a way to convert your existing manual window mechanisms in the old forums (I'll look for it in a moment), but you'd need motor units which work on a similar "flexible rod" design window-winder mechanism.
Note that the window winding mechanism in the Golf Cabriolet doors (both manual and electric) is entirely different than the ones in the doors with window-frames. You might be able to get the Cabriolet mechanism to fit into a framed door, but it would probably not be easy.
I found the link to the old forum post (see below)
Note that it assumes that you already have a motor drive unit on a (worn-out) non-VAG mechanism, but the procedure should be much the same, after you have successfully found a similar motor on a (non-Golf) scrap car.
http://www.campaignreg…forum/viewtopic.php?t=468
Note that the window mechanism is different on the front doors of 5-door Golfs (just in case you were going to measure off one of those…)
Life Member
http://www.pca1.co.uk/…product_profile/index.htm
Electric Life / Poole Clayton are the best know supplier here in UK.
You need kit no. VK03 9904, pricey though at ?236!
Rajan
<p><span class="postbody">
Guest user
Guest user
Right-click on it and save it down to your PC…
Guest user
A bit thick and all that.
http://www.sciroccoregister.co.uk/images/green_mk1_int.jpg" width="318"></p>
E-Bay lists a conversion kit…current bid is ?50 and ends Wednesday 5th Evening at 8:40pm
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=9889&item=4515637733&rd=1
It listed as suitable for Mk1 but buyer beware
Mk1 GTI
B5 Passat Estate 5 SPeed
Riley 1071"S" Elf Mk2 (Bl**dy Hooligan machine!)
Bosch Lawnraker 32
Bosch Lawnraker 32
My Build Thread
