Cabby hydraulic roof ram removal
(In Topic #240451)
Seeking a 'how-to' guide
Yes you can open it with the rams removed but it is very quick as in Heavy, and if you allow it to free close you may break your rear window.
Same as when you open it with no rams or Struts, a Wee bit difficult and Heavy. I have always had Manual Tops. When my struts went, I had to take the bottom clips off, to let them free. When opening the top it was a Ballet of popping the Latch, and lifting it on one side a wee bit, then going over to the opposite side, and praying that when I unlatched the other side and lifting it up, the other side wouldn't re-latch…
Rams are nice and convenient, how ever Manual tops don't have leaky rams that are temprmental, and the rear struts are easily replaced, with a well oiled frame, I can go topless in about 0-10 seconds .
Craigt said
Ideal, thanks. I shall remove and get refurbished, probs not raise /lower when rams are missing. Just need chortle to confirm he'll do the refurb, or point me in the direction of a suitable supplier ;-)
Hi Craig, did you manage to get the rams refurbished? I'm looking to do the same with kine as they're leaking fluid all over my boot
Hi Craig, did you manage to get the rams refurbished? I'm looking to do the same with mine as they're leaking fluid all over my boot
Ill report back.
Sent from my SM-G981B using Tapatalk
You can also try to use the manual motor valve and see if you can change it's position a wee bit to ease removal…
Still don't know why it was getting jammed but both my rams are out and I'm looking to get them refurbd
