Tintop GTI history A576 UDM. JUST SAVED /
(In Topic #218932)
Odd place to put the fuel filter when the engine was in there, right next to the heater blower you would not want any fuel leaks there, nice big hole into the cabin for fumes or flames!
Strange in the lasted pictures the scuttle has been cut out..
They tryied smooth bulk head
Not sure what going do with bulkhead they wrecked it I think
Thinking putting a tt under it.
I think be easier fix swapping body's
Yes aerial hole still in roof as well.
I'm just sad bulkhead being hacked no.id number anymore Going get bit plate stamped and welded in somewhere
Not going start for yr or so need finish caddy pickup
Was on eBay £850. I give quarter that
I've already fitted glass and roof to keep it dry
Just bought a mk4 golf gti 18 turbo AUM running gear to drop in
Does any one know someone can do imm delete on ecu
Save fitting full harness and clocks
Don't really want weld in coloum
I'm doing conversion from mk4 golf gti
Got coloum and frame from that do I just fit this
Regional Host NE
Ashton09 said
I'm just wondering how to bolt in steering coloum since bulk head being smoothed no holes in sight
thought you were going to pop
over and make yourself a template
mate
Not much but every little bit helps
Door post repaired where hinge was chopped off
Power steering rack bracket done and fitted
Mk4 golf servo fitted to bulk head with clutch cylinder
Was bit of pain with the mk4 golf adjustable column fitted
Mk1 golf fuel tank modified take mk4 golf gti tank unit
Mk4 golf full harness just about all in
It's bulk head what took time to repair I add photos later date
My goal was get it running by Xmas but always next year
Feel like starting get somewhere floors, sills, chassis axle mounts inner and outer wheel all done
