Cooling (again)
(In Topic #238165)
For whatever reason my cooling (again)
both of my last topics fixed the timing and the VDO gauges. Splendid!
Next problem arose rather quickly.
Was driving to the hospital in a city next to mine, via the highway. ran perfectly and on normal temperature.
However, when i came down from my 110 kmh to so traffic the thing overheated faster than i couldve imagined.
got it towed home and took a look, (everything was semi-&$%£&*)
I replace the water pump & water pumphousing & the thermal switch the fan kicks on perfectly at 87 Celcius now, every time. and keeps going after i shut the car off the overheating hasnt been fixed however. and there my question comes forth, i dont expect the radiator to be bad, since it has always cooled as it should and never did anything suspicous. my only ''suspects'' are the coolant-overflow-tank and its radiator cap (the tank itself has a molten smel?) & the oil cooler.
would anyone have an idea?
perhaps someone with a simmilar experience?
how do i check the oil cooler?
Thanks lads!
If you didn't flush and black flush the coolant system and heater matrix, then you have missed a step.
If you didn't take the radiator shroud and fan off to inspect the radiator matrix, oppsy, never assume.
Especially of yours is the bottom side bolt and upper c-clip version
Expansion tanks go bad, as well as caps.
Also check all hoses for bad spots.
Another place of contention, is the lower heater hose connector, they are plastic and a time bomb.
Replace it with a Pex 5/8 pex or hose coupler connection. They are made of aluminum or brass, and a couple of clamps.
Hose connector
pex
If you have plastic outlet flanges, then check them as they can leak at the bolt holes.
You need to know for sure that the coolant is circulating properly.
I would go from there.
i fully flushed back the system for a second time and nothing really improved. The thermostat was replaced and this did precisely nothing!
coolant is circulating as it should, thermostat opens perfectly at 85 Celcius (measurement might be a tad bit off)
pump housing and seal was thoroughly checked for the entire day, absolutely zero leakage of weapage whatshowever/
the pressure on all cilinders was checked and no leaks to or fro the cooling channels or the outside.
all hoses are good, nothing bad yett, im waiting on a new expainsion tank and cap.
*IF* and shall we hope not, the reservoir and cap doesnt fix it, im just ordering a new radiator.
I assume it's definitely overheating and not just a fault with the temp gauge?
When up to temp - no leaks anywhere, Top hose is hot, bottom hose less hot? Fan kicks in?
Cabin Heater on hot with fan blowing hot air? Hoses into matrix - one hot and one less hot?
Hmmmm - can only be the reservoir cap or head gasket….
remove res cap.
tie latex glove over the opening tight.
heater to full hot.
Start the engine and rev it to 3000 rpm 30 to 45 seconds.ant longer and it will inflate with the coolant getting hotter.
If the glove inflates and give you the finger mad hear gasket or water jacket oil cooler.
If you run your engine and the fan cycles 2 times, and your hoses are hard to squeeze bad head gasket.
Def not a sensor issue, car gets too hot. Engine dies and doesnt want to restart.
Reservoir & cap just came in. The storage location where i keep my golf is now closed till thursday, i will keel you updated
Defenitly hope its not the head gasket as i got that checked out a month ago and it was totally fine said the shop.
For question, you say tie a latex glove on the reservoir thread. If that fully inflates the head gasket is 👍🏻 if it doesnt fully inflate the head gasket is 👎🏻
Fan kicks in perfectly every single time and the hoses arent hard in any way. Feel brand new.
Last edit: by Marauder
Marauder said
This sounds like a plan,
No, if the engine is cold.
Start the car and rev it to 3000 rpm for 30-45 seconds,
If the glove inflates during that time the head gasket is suspect.
The glove will inflate after 45-60 seconds any way. but it it the first 35-45 seconds at 3K rpm.
water jacketed oil coolers also leak.
Aha!
If i got this correctly, its now time to pray for the glove not to inflate in the first 45 ish seconds, (at least not too much)
if this, and the new reservoir and cap situation doesnt fix it ill report back!
Thanks alot!
