Manual gearbox
(In Topic #232626)
Drain & top-up
Most folks including myself re-fill it from the Speedo cable hole, when removing the speedo lift both sides of the car off the ground support on Stands, then remove the 10mm bolt that holds the speedo cable in. Car in Drive ebrake on, rotate the front tires a little left and a little right this shoudl remove the bind on the gear to allow you to get it out BE WARNED the gear can fall off the cable as you pull it and then you are looking at a whole different ball game…If it feels stuck, then rotate one of the wheels in reverse gear and try pulling it up and out..If it is binding let -her- alone and use the top fill plug.
Good vid with good view.
How to Drain Gearbox Oil | How to Refill Gear Box Oil. VW Golf. - YouTube
Where not to fill from.
VW GOLF MK1. HOW TO CHANGE GEAR /TRANSMISSION OIL, AND TOP UPS (TIPS) #golfmk1 #golfmk2 #vwfox - YouTube
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=how-to_2%2Fguide-changing-your_6
On level ground and car on its wheels use a bottle with a long filler tube and squeeze the oil in till it runs out, I do lift the passenger side a little to add just a small amount more oil as I find 1 and 3/4 ish Litre will fill the gearbox.
It's not easy getting access to the speedo drive with a fuel injection engine and the plastic drive cog can fall off the cable into the gearbox which is not easy to get out. Why risk it when there is a filler hole….
http://brokevw.com/020oil.html
What oil are you going to use as upgrade to fully synthetic oil will help the cold 2nd gear crunch.
