Ignition switch replacement
(In Topic #226785)
Stumped with the key/barrel assembly removel on my mk1 90 gti.
Got it all stripped down but the silver bit wont slide off the steering shaft, got the bolt removed and the steering lock isn't engaged so dont see why it wont slide forward, it does have a small amount of rotational movement but zero forward.
I have tried it with the barrel in and removed still nothing!
Regional Host NE
I have the shear bolt out and separated the 2 halfs slightly but still nothing, no forward movement at all.
Do I need to remove the spline adaptor where the steering wheel slides on to?
Sent from my SM-T720 using Tapatalk
Then the key has to be turned to release the steering wheel lock. Sometimes you have to slightly move the shaft to release the lock. If the lock isn't released you won't get any movement on the shaft.
