Torque settings for sump bolts - Mk1 Campaign
(In Topic #224075)
Going to put a new sump on this weekend.
Have the sump and a rubber gasket.
Haynes manual (the Brown manual) says:
Socket head torque = 5 lb/ft or 8Nm
Hexagon head torque = 14 lb/ft or 20Nm
I have typical bolts == Hexagon head so that means 20Nm.
However did search on here and someone recommended 87 lb/in which equates to 10Nm.
Want to get this right as over/under tightening can cause leaks or damage.
Any thoughts?
Dave
Bolts are M6 with hexagon head.
8 Nm is more than enough.
And torque the bolts gradually and in a crosswise sequence.
20 Nm is used for M8 bolts.
Greetings Kris
20nm, Fugeddaboutit…
Will go with the 8Nm.
Cheers!
Any views on sealant?
