Electric Windows
(In Topic #223448)
On the drive
Myvalver 89 GTi Grey mk2 16v
On the drive
Red-or-Dead said
Would that be the cause of both windows just stopping working?
A bad ECM or window controller module under the dash.
Usually Caused by rain drains in the Scuttle Tray being plugged and allowing water to migrate through the scuttle and over the ecu.
Everything I know about Electric windows can be found here.
A1 Cabbie Power Window Problems | VW Vortex - Volkswagen Forum
WTB: Window control module | VW Vortex - Volkswagen Forum
https://forums.vwvortex.com/showthread.php?2207505-Ooops-I-let-the-smoke-out-of-some-wires-(window-issues)/page2
Controller
What it looks like inside:
Like Brian says check box,but that's only if its oem ..aftermarket are but more basic..pull switches out and have alook for connection. Similar to what's behind most radios. Was all working ok before?
On the drive
You won't "SEE" a blown fuse under the Dash, it isn't unless you measure voltage on both sides to ground, or take it out and see the burned mark…Red-or-Dead said
I can't see that a fuse has gone.
Take the controller down and out and verify that a spring isn't off the relay, or corrosion, cold solder joints..Broken pins, Wires that are broken in the door fold, there are a ton of things that it could be,,,, I had one where the wire was broken in the Bend, and if I opened the door with it would work, if I opened it slightly it would die….
The fuse panel is as:
Thank you Kammy, from Cabby-info.com.
If you cut that wire and Tape both ends, then when you get the module working, you can roll the windows up or down for about 10 minutes after the key is out.
If you forgot to roll the window up after you have opened the door, then just hit the switch and the windows will roll up.
A multi meter is great investment even a cheaper 10£ version will be great for chasing issues.
On the drive
Red-or-Dead said
In the car now. Fuses are fine. Got a multi metre. Can't work it!
Haha you just have to open door.card and pop on the connector to motor with it set at dunno 20v should say 10-13 on gauge when power window pressed be it analog or digital.
Multimeter….Plug the black probe into COM and the red probe into the socket marked VΩ. Set the range to DC or AC volts and touch the probe tips to the two points between which voltage needs to be measured.
On the drive
