K-Jet Experts - please help (latest update Pg 6!!)
If it were me, I'd adjust the idle screw to try and get it running - by winding it out you should get the same effect as feathering the throttle (e.g. a bit more air).
Like you say, you can then mess with other elements.
J
I'm not sure if what you've done with a feeler gauge is accurate, I've only used it as a rough guide to make sure the timing isn't 180deg or so out.
I'm also fairly sure the belt being one tooth out would not cause the roughness you have now so have a go at the ignition timing first then check the valve timing.
There could be a way of checking it but with no mark on the pulley I can only think of taking the bolt out of the Vernier pulley, lining up the old pulley with it and transferring the mark.
If you can't get it to idle as paceman suggests loosen the distributor and get someone to feather the throttle while you turn it by hand until you get the smoothest spot.
if the hella spark module didnt give you spark perhaps there is a bit of ropey wiring or loose pins around that area. if it really is bust then just send it back no problem.
try and get the ignition timing done first, as any adjustments to the timing will throw out your base idle and co settings so you dont want to waste a load of time doing that only to have to do it all over again
Feels like a big step backwards to move forwards but as you say, I need to start from the correct base setting to give me a fighting chance.
Thanks to everyone for the continued support with this, the input from the forum has really been essential.
Original cam pulley removed
Removed the vernier pulley and compared the 2, my timing mark looks to have been ok (I marked the tooth with the red paint, the actual timing indentation is between teeth so half a tooth off).
Once I'd marked the vernier with timing dot in black pen exactly as per original pulley mark, I refitted everything and re-timed the engine:-
Cam pulley
Crank pulley
Flywheel marker
Distributor lined up on No.1 plug lead with cut-out in dizzy body
Put everything back together expecting it to fire into life…..no joy. She's just turning over, will give a pathetic attempt to fire if I pump throttle pedal. I stopped when she did a loud pop back through the inlet manifold. The timing light says I am still sparking ok. The smell of fuel tells me there is petrol getting somewhere. I tried adjusting the mixture again to see if I could find a sweet spot but no joy.
Have a look in this thread for cam timing marks..
View topic: Help confused- Timing marks - The Mk1 Golf Owners Club
No one else in Northern Ireland on here who can pop over to help or have a look over incase they spot something??
mark1gls said
The Cam shaft timing marks are set along the face of the head not the cam cover, it's hard to see from your picture if it's in line…
It's as per this diagram Mark, lined up with inner timing belt cover.
I'll be honest, I never even considered this as the head was fully rebuilt by the Man in the Shed, and he re-shimmed it to match the Schrick cam.mark1gls said
Just another thought you have the older style head with shims have you double checked all the clearances with a set of feeler gauges?
Last edit: by Pistol
Might explain that massive backfire through the inlet manifold on my last attempt to start.
I'm sure I saw a post on club gti about setting valve timing on a performance cam. I'll see if I can find it again.
I'm getting a bit panicy about mine now - it's still a ways off, but given I have far less new parts, and much more really old parts, I'm not filled with confidence!
Surprised there isn't someone over there that knows about these things.
Have you put anything on the FB group? - I think there are plenty of folk on there that never visit the forum.
Mad idea, but could you pull the metering head off that other one you've got and give it a go? That must be the only thing you haven't touched.
