K-Jet Experts - please help (latest update Pg 6!!)
(In Topic #223014)
1. checked for spark by pulling a plug and turning over and seems fine
2. pulled numbers 1& 2 injectors and I’m getting no fuel at all
3. cracked the 5th injector and I’m getting fuel there ok
4. I have fuel supply to the metering head
5. pulled the fuel distributor and the plunger is moving freely & looks like new (the distributor was not disturbed during resto, just removed as a complete unit for cleaning/painting).
6. I read a few posts on here that said the air flap might be sticking, just checked that & it’s super smooth & free moving.
I also seem to have a bit of fuel in the air filter. When I push in the plunger in the distributor I’m getting some fuel leaking out at the plunger, is this normal?
i guess my next step is to lift the flap manually while attempting to start to see if I get fuel at the injectors? If this works, what is wrong?
thanks in advance
Peter
Last edit: by Pistol
Could this be an ignition related fault? I'm wondering if I have a bad earth somewhere, as my VDO gauges are now going full scale when ignition live, and the indicators are not working and the green dash light is lit. Hazards are clicking the relay, but only drivers rear is operating. Teething troubles!!
Regional Host NE
When I try to lift the airflow plate while cranking engine, the resistance is quite strong against the pressure pushing down on the plunger. It's not the plunger sticking cos that's freely moving & so is the air flap when the fuel pump isn't running.
It seems a pressure test kit specific to K-jet is not readily available in the UK, but would something like this work? I've just realised it doesn't have a valve, and may not have long enough hose.
https://www.ebay.co.uk/itm/303469743242?_trksid=p2047675.m570.l5998&_trkparms=gh1g%3DI303469743242.N35.S2.typeBID_ITEM_ENDING_SOON.R1.TR3
Regional Host NE
would still fire or attempt of the cold start injector
surely
Watched this the other day, pretty decent vid on pressure testing k-jet K-Jet Fuel Pressure Testing - YouTube
Looks like he made his own tester. Can't tell if the one on ebay will have the right bits, but for 20 quid it's worth a punt even if you then have to buy a couple of the correct adaptors.
I'm not sure what the right system and control pressures are for a different WUR or whether you are supposed to set them to std (for a dx) as they will be wrong on that WUR. Do you still have the original WUR? You could swap that in to see if that solves the problem. At least then you know the culprit.
I'll think on and see if I come up with any better ideas.
J
I've got a gauge that a local hydraulic workshop made up, the ends are not metric and not a perfect fit but it does the job, I'll take a picture later on.
did a search and stumbled across this:
"If your system pressure is low - or if your WUR isn't working properly, it won't run right. On mine, the WUR was completely blocked, so the control pressure was the same as the system pressure - 4.5 bar of pressure pushing down on the plunger, which makes it harder for the plunger to lift and let fuel to the injectors. "
Good way to search the forum is to use goggle like so:
site:vwgolfmk1.org.uk control pressure
I've noticed that rubjonny (aka John Newman) has some useful doc's in his collection - he has a link in his signature.
Good luck!
Sorry if this is stating the obvious.
And I put the original WUR back on, but still not starting. Everything else is original apart from the throttle body itself and the uprated cylinder head, so I'm a bit stumped.
If you can connect your pressure tester as before but with no leaks and the gauge is on the WUR side of the tap you can read system pressure with the tap closed, if you only have 3 bar that will be your problem or part of it
From memory the four main injectors need about 3.5 bar to open.
New Bosch 0580464126 5bar fuel pump
New Crazyquiffs flexi fuel lines
Injectors ultrasonic cleaned and bench tested
New HEL braided injection lines
Airflow metering head assembly has not been touched apart from cosmetically
New Bosch fuel filter
Fuel tank internals are spotless, new fuel used from a new fuel container.
No kinks in the fuel lines?
How long has the metering head been sat? Not sure if they can gum up, but I'd figure that because injectors can, so could the metering head.
You can remove the plunger from the metering head without disturbing the magic inside, but as you say that is moving freely, I'm not sure if you'd see anything untoward.
cedar said
I've just spent 10 mins looking at shiny parts that I want (but may not need!).
