Where does this go?
(In Topic #220281)
Regional Host NE
there the return spring is just above
the push rod clevis pin mate
Should I look at replacing the return spring or is the pedal meant to be slightly lower?
It's normal for the clutch pedal to sit a little higher.
What's that blue box attached to the accelerator pedal? That's not the normal fitting for the accelerator cable…..
Are you running a different engine?
Regional Host NE
I removed the bolt and spring, thanks guys.
