84 gti K Jet
Not running properly
handiman42 said
Just looking at a post on :fuel systems and exhausts; about changing injectors I had air shroud in mine and I changed to non air shroud Should I have changed the inserts as well Regards Dave W.HI Mark I see your online , What do you think about the inserts…..Regards Dave W
I don't know as I've only ever changed my injectors like for like, air shroud with air shroud.
I would not attempt removing the inserts with the head still on the engine as they have plastic ends which over time go brittle, when I changed my inserts there was lots of bits falling off the inserts as you can see here.
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=helllllpppp%2Fwhich-injector-inserts
front calipers are VWII, for 239mm discs. same ones are used on mk2 & mk3 golf and various seat/polo right up to 2002ish and maybe beyond. watch out for very late ones as they might have banjo bolts.
for repair kits VW still stock the parts for the guide sleeves but the piston seals are now NLA. speak to biggred.co.uk though they're sure to have everythign you need
Next if you havent already got one, buy a proper brake pipe spanner, like this:
https://www.ebay.co.uk/itm/312392978361
Then cut the flexi pipe so you can slip a ring spanner up it onto the joint flats so theres no chance of rounding that off either.
Cross your fingers, and go Worst case you'll have to make up another hard line section, its not hard to do yourself just make surte you get a good quality flare tool which can do DIN flares. Or pull the pipe off and pop to local garage and ask them to make a new one up for you
I use Crocus Cloth or wire brush to polish the lines behind the nut.
Where the Hardline connects to the Frame at the top, you may want to use a backup ie: Small vice grips to hold the back side of the fitting. I have had the dickens of a time or two on the rear rubber hoses.
Regional Host NE
has the problem been resolved
I would bleed it again a time or two as it can be troublesome to get all the air out after a MC swap, if it still is wonky, then I would suspect that your new MC has issues.
I have had to replace new-remanned MC's more than once, and after that fiasco, I only buy new, or get a seal kit and re-build it myself. Which is why I only buy local, and the last one I had to remove and replace I made sure that the Autoparts Store refunded me for the Brake Fluid I had poured through.
So don't discount that just because you replaced the MC it is good.
But from your description I would be suspecting the MC.
Google make your own power bleeder, make bleeding a one person job and tends to force all air out. If you are using a "mity-Vac" and didn't wrap all the threads of the bleeder ports with teflon tape you can actually suck air in via the bleeder ports, and not suck fluid.
My home-made power bleeder is such a nice thing.
Regional Host NE
yet just interested how it is resolved cheers guys
Regional Host NE
handiman42 said
Hi every one ,Iv,e been trying to find a repair kit for the front wheel cylinders for my Mk 1 1984 gti convertible tThe calipers are ate , and nobody seems to do them.Anybody have any ideas Thanks in advance Regards,Dave W.
handiman42 said
Thanks for that Mark,I will give that a go, do you think there is a fault with the servo, I checked it as per the haynes manual.Ie.holding the foot on the brake and then starting the car.The pedal goes down once started.Is there any fluid that runs through the servo ?? Regards Dave W
hi surely fluid would not run through the servo
if it did the vacuum would draw it into the inlet manifold due to the vacuum which the servo works with and burn it in the engine causing a plume of whiteish blue smoke from the exhaust
Regional Host NE
for mate
