Just need some clarification
(In Topic #219623)
Right guys as titled
Just want to make sure this gasket was mounted the right way round as I've seen others with the spare loop on the other side before
Secondly this is one of the many hose in and around the inlet, question is this one appears to be capped off and blocked.
Is that correct?
Current rides:
not sure if this helps but the pipe coming over the inlet looks like the one capped off on your car. gasket looks ok to me
Only reason I ask about the gasket is because it did have a slight leak
Current rides:
It will fit ok with no problems but VW would of fitted a gasket with out the loop so it's been changed some time in the cars life. The one VW fits to fuel injection cars is like this one..
https://www.ebay.co.uk/itm/MK2-GOLF-Inlet-manifold-gasket-Mk1-2-Golf-Jetta-T25-Diesel-models/181750086280?hash=item2a51263a88:g:pgYAAOSw4qxap6O3
It's worth wrapping your steering UJ rubber boot as when you fit the 4,2,1 manifold it will be very close to it and the cost of a plumbers mat is a lot cheaper than a new rubber boot as scene tax has pushed the price up to a silly amount….
I used a mat like this and a couple of cable ties to hold it in place, it's better if you use metal ties like when you wrapped the down pipe…
https://www.ebay.co.uk/itm/Heat-Resistant-Soldering-Brazing-Plumbers-Mat-300mm-x-250mm-Woven-Glass-Fabric/231607785661?epid=1988749576&hash=item35ece658bd:g:hHUAAOSwyQtVkQWm
Looks like have also found some money stuck to your inlet manifold…..
Not sure on the pipe as it’s to cold and dark to go out side and have a look at my car, I’ll check tomorrow.
Oh yeah looks like some kind of roman coin stuck on it.
Current rides:
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=projects/your-mk1-golfs_2/my-daily-drive-1988-gti#post_1502165
Thats a good read, fantastic numberplate and that scirocco is beautiful.
Did you ever get the stain off the driveway
Current rides:
Lucky the number plate came with the car when I got it.
I do enjoy the Mk1 Scirocco it's like you sit on the Mk1 Golf with the windscreen in the near upright position but slide into the Mk1 Scirocco as the roof is lower, sloping windscreen and you have to sit lower and more laid back. A lot less Mk1 Scirocco about now a days than Mk1 Golfs and for some reason they seem to be worth less than Golfs… Not that I ever intend to sell mine, it’s now road tax free…
The stain has finally come off the driveway and the couple of miles up the road I drove with oil spraying out, the smoke cloud behind me gave the game away that something was wrong… lucky I always have some spare oil in the boot as when I stopped to see what was wrong it was well below the minimum mark on the dip stick, I put in 2l of oil and drove home. It all went pair shaped because of a rubber seal which looked a little hard and I planed to change at the next oil change as you have to remove the oil filter and lower the oil cooler to fit, took a couple of minutes to fit new seal…
If yours looks old it's worth changing it at some point, the seal sits on top of the water feed oil cooler if you have that type and not an air cooled oil cooler…
https://www.ebay.co.uk/itm/New-Genuine-Febi-Bilstein-Oil-Cooler-Seal-18776-MK1-Top-German-Quality/192390191557?epid=249525852&hash=item2ccb5959c5:g:w7gAAOSwUoNaKanS
Last edit: by mark1gls
