Kr won't start help please
(In Topic #219125)
Another kr problem
It normally only prevents starting when warm, because the 5th injector should fire when cold - does yours?
It can be easily tested by squirting Easy Start, or petrol, or brake cleaner etc into the air intake just before trying to start - it will be enough for a few seconds, to start the car, then the fuel pressure will probably build up.
Check the obvious - that the pump isn't restricted (small filter blocked up on its inlet?) poor wiring, poor relay, and the 5th injector etc
