"TAG" - 1983 Campaign restoration blog
When the car goes to the paint shop I will get the whole lot topcoated/lacquered - but clearly some areas will be unreachable for him - but this way I know that everywhere is treated/painted.
All looking rather better now than when I started!
What I thought was a couple of rust bubbles son developed into rather more……….
Also the holes holding the lower spoiler were bad as well.
A trick I read about online, and that works very well I found is to use some old copper (I used some 15mm copper pipe flattened in a vice) - clamp that behind the area you are about to weld. The copper draws the heat away to prevent blow-through and the weld will not attach to the copper. Rather useful trick that was very useful in repairing the thin metal of the flange.
Removing the main glass was easy but the front quarter light was a little more involved.
For those who have not done that job:
1. Self tapper screw at the top of the glass support bar.
2. Rivet to drill out on the support door - on the inner door panel near the interior door release hole.
3. Rivet to drill out underneath the door.
Then pull the support bar at the top and towards the back of the door to free it from the quarterlight rubber.
Then after a bit of careful wriggling/persuasion (!) it will "JUST" come out the from the bottom of the door. It is a surprisingly long item actually.
So cut out the grot, made a pretty intricate and awkward shaped repair and welded in. Finally added the holes for the ventilation flap.
