84 gti K Jet
Not running properly
I would think about taking the head off and having a look, but up to you as head work is a few £££..
screw compression tester into No.1 and crank the engine on the starter motor till the gauge does not go any higher, (usually takes about 30 secs of cranking) take the reading then move onto No.2 etc.
make sure your battery is in good condition and fully charged.
Don't pump the accelerator etc while cranking the engine over as you don't want fuel vapor floating about.
This is how I've done mine before but there may be other ways??
I ran my engine for about 5 years with low compression on a couple of cylinders, and it still kept going till I could find the time/money to get it sorted.
mark1gls said
I remove all the spark plugs and rotor arm from the dissy.
You can also take out fuel pump relay, to dissable fuel pumps.
http://b2resource.com/PDFs/wurfix.pdf
https://www.ebay.com/itm/Rebuild-kit-to-fit-Bosch-Warm-Up-Regulator-WUR-MERCEDES-PORSCHE-VOLKSWAGEN-VW-/272712635916
