Bought my first mk1 golf
I've pushed off my install until I can get these components.
Some places do sell just the shorter bump stops and covers, I think the ones in the kit are made by Febi but not 100% sure?
I have before cut a section out of the bump stop and glued the 2 ends back together but over time the glue breaks and you need to re glue them back together.
Where did you buy the bulb kit?
I've been thinking of doing it, but not sure how many of what type of bulb I need.
simongood said
Looks good! Even the clock is lit.
It needs 3 bulbs 1 for speedometer 1 for rev counter and 1 for the clock. Check that they're all working before putting the full dash back together as I did to find 1 wasn't working 😡. You can get them off vw heritage or also on eBay.
I've been recommended using this stuff on here for my vinyl roof to keep it supple and protect it from sun etc, can't comment on how good it is yet as the roof is only 6 months old, but when I did use it the water beeded nicely on the roof and just blew off.
I guess you have fitted another vinyl roof?
https://www.ebay.co.uk/itm/303-Aerospace-Protectant-16oz-Spa-Plastic-Leather-Fabric-Hot-Tub-Vinyl-Cover-Car/150795891272?hash=item231c22b248:g:g9wAAOSwt4xafH8l
mark1gls said
Well worth the expense of a new roof to keep the car water tight.
Thanks I'll have a look into buying some of that, yeah I've gone for a like for like swap vinyl roof luckily it was included in the sale so it's only cost me to have it fitted 👍🏻
I found this info for your chrome grill: "There is also what is known as the Hella grille insert which is the same as a '79-'87 grille except it has lights in the center section. This grille came stock on many Cabriolets in Europe. If installing this grille on A/C-equipped cars, the A/C condenser will most likely need to be relocated or removed. (Also available in aftermarket versions as well as badgeless.)"
My car is in getting some spot paint work done. Hope the blending turns out. BTW if you need to touch up the paint, our paint code is Bronze Grey Metallic LA8Y.
All info from Home
simongood said
Thanks for the bulb details Brad . I need to find a replacement clock as well, the LCD has run in the corners.
All info from Home
I've been searching all day and found the same info about the hella grill but cannot seem to find a new 1 anywhere, there's 1 on eBay but the plastic has got a crack on it so not going to bother with that!
That's abit of a pain regarding the new cluster for you 👎🏼
I was looking for a LCD clock replacement and found these chrome trim bits:
https://www.werk34.de/product_info.php/info/p9108_Trim-set-for-grille--4-piece--chrome--Golf-MK1.html
Might be what you were looking for.
Not changed my roof as it's dry stored.
Mr Kenneth has supplied new waistline trim (yet to fit it )
I drove to Gloucester to see another same colour as on left.
Happy motoring.
Ps was new roof vinyl or canvas.
Sent from my SM-G901F using Tapatalk
What's next?
Mk1 second project cabriolet
MK1 first project cabriolet
hopsandmovingon said
Like the colour so much I bought one
Happy motoring.
Really smart the pair of them, I always preferred the tin tops but as soon as I saw mine in this colour the cabbys have really grown on me!
