84 gti K Jet
Not running properly
If so you have air shroud injectors, the injectors with out the top hats are non air shroud injectors, you can fit non air shroud injectors but you need to block of the air hose between cylinders 3 and 4.
I'm surprised if you do have the later air shroud injectors, has the engine been changed at some point? I could be wrong and 84 cars did have the later injectors….
View topic: Are these suitable O Rings for my injectors? - The Mk1 Golf Owners Club
also, is your engine a 1.6 or 1.8?
https://www.onlinecarparts.co.uk/oenumber/049133551a.html
Last edit: by Deandubya
Last edit: by handiman42
Best if you can pull out and injector and undo it from the fuel line and check the thread of old injector to new injector.
If they are the same thread block off the rubber hose between 3 and 4 as you will have an air leak in the head and fit the new injectors.
If the threads are different then either replace all 4 fuel lines for early fuel line or change injectors for air shroud type.
Pictures of different threads,
Non shroud with 4 threads
https://www.ebay.co.uk/itm/VW-GOLF-MK1-CABRIOLET-SCIROCCO-STORM-FUEL-INJECTOR-VALVE-BOSCH-049133551A-A888/191630779767
Air shroud with 5 threads.
http://techtonicstuning.com/main/index.php?main_page=product_info&cPath=2_11_790_791&products_id=642
Some more info from older threads..
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=big-block-injection_2%2Fadvice-on-injectors
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=big-block-injection_2%2Finjector-hose
Google for more info.
New air shroud injectors on eBay.
https://www.ebay.co.uk/itm/VW-GOLF-Mk1-1-8-Petrol-Fuel-Injector-82-to-83-DX-Nozzle-Valve-Bosch-049133551A/232409894876?epid=1141735501&hash=item361cb58fdc:g:JhwAAOSwpHFZaVXL
I've not done this but read it on here.
new injectors /new fuel filter /new lift pump / new fuel pump relay / motor still doing exactly the same .ie. having to tickle the throttle for a few minutes.to get it to tic over at around 900 revs, then the motor runs ok. for about 10 minutes then starts missing and back firing into the air chamber I have removed the pipe between 3 and 4 ( because they are non air shroud injectors) and blocked up both ends , but the motor does not run any differently either way Shoud it….Regards Dave
The mixture may also be out???
Sorry I can't be any help with recommending anyone one…
