Removing instrument panel - immobiliser.
(In Topic #210380)
I am trying to remove the instrument panel, however the immobiliser fob does not allow me to have any manouvre, i believe even if i try to remove the steering wheel it does to not give me much room or access to the Speedo/rev as i am trying to change the lightbulbs in the dash.
Please look at the picture attach - would welcome some feedback/guidance.
just try to track wires….could be loop with extra lenth
two wires, separate the wires from each other….at the rear and clip each one Separately… One at a time….
Leave enough wire so you can use a set of insulated male/female spad connectors to reconnect them….
Its a Laserline immobilizer butnnot sure what model or make
I have the same immobiliser and that's where mine is.
Re:
Ahh cool - ill have a look above the pedals and see whats out there. Is the cover easy to move?mark1gls said
Have a look for the immobiliser box above the pedals, remove the cover above the pedals to get there.
Im really intrigued to know what model it is.
Do you know what they key is for on the siren 904?
You can disconnect the fob from the the box if you look at these links you can see it plugs into the box.
https://www.ebay.co.uk/itm/Genuine-Laserline-alarm-immobiliser-touch-key-fob-remote-and-receptacle-/382386001242
https://www.ebay.co.uk/itm/Laserline-921K-Thatcham-Approved-Category-2-TouchKey-Immobiliser-and-two-keys-/171173897818
make sure you have the car battery disconnected before do any of this.
the cover above the pedals on a cabriolet has 2 plastic clips which you unclip then pull the cover down, it’s also held up by a couple of metal tabs on the bulk head.
