What's this?
(In Topic #208169)
was this one actually in use? later engines have the thermoswitch(es) in the front flange. if you need this piece its been NLA for a while so it could be a bit of a struggle to get!
single thermoswitch pipe is 055131223D or 056919369B depending on your engine code, 2 switch one is 035919369
Last edit: by rubjonny
https://www.vwheritage.com/vw_act_vwclassicParts.search.htm?classicSearchType=pnum&classicSearchText=035919369N
the 035919369N is similar but the black thermoswitch is the wrong rating for the autochoke it will cut off too early, from goo0gle images it does look like it has threads in the side if so you could drill a hole in one of the blanks and use a later carb threaded thermoswitch. or you might be able to swap the old white sw2irtch with the black one, though im not sure how they are attached… looks like they may be bonded in?
or if you have any spare sensor tapping in the front or side flanges you could get the dual one and fit a later carb choke thermoswitch there instead
