Help with Front Wiper Washer
(In Topic #202819)
I have the wiper washer motor for the front windscreen on my 83 GTI but I find no cables nearby… I do have some cables so if anyone could let me know the colour of those cables and where they come from I would really apreciatte it!!!
Tks
Thanks, my car is LHD, the connector would be on my driver´s side?
Tks
Max
I found two wires one
Green/red and one white/red.
Brown is ground, may I use other ground?
Any hints what White/Red could be?
Below is a picture
Thanks!!!
Max
I would take a closer look at your wiring, it looks to have had some wiring repairs so the wire colours may not be correct. I can see a taped joint where a brown wire has a white connected to it for example…
Member 125 - 2005
Member 125 - 2005
Through the windage tray above the speedo cable
Anyhow first I will test the wiper washer and let you know!
By the way, The Econometer Gauge for 5th gear works perfectly
Thanks for your help!!!
