ABF Conversion - Crakshaft Pulley
(In Topic #202689)
Just prepping for an ABF swap into my mk1 cabby
The ABF came with air con - which I have deleted along with the power steering too,
Im swapping the water pump pulley for ribbed type off an 8v mk3, but……
The Crankshaft pulley still have the V belt pulley part attached - do I need to remove and swap this out for clearance on the chassis leg or can I get away with leaving it - does the v belt part of the pulley provide balance/dampening?
I see it can be split but it looks a bit crusty (i'm changing out the fixing bolts anyway) and don't want to end up with a knackered pulley - crank wheel off anything else fit - non PS KR possibly?
Any advice appreciated
Steve
best to take the crank pulley off anyway as you'll want to put a new timing belt on
Its not long had a belt and all the usual seals done by last owner (although I'm doing them again as there is an oil leak) - although the crank sensor o ring is torn up
Anyone know if the o ring can be gotten seperate?
crank sensor oring is 021906445, 3.23+VAT
