Sportline MFA pcb - blown resistor identity
(In Topic #200871)
Resistors are only a few pence from Maplins etc.
jellybelly said
this is a seriously difficult one
the only way of truely knowing is either get another set of clock, check and replace or finding a diagram for them
I bought a replacement set of mk1 gti clocks, but the pcb was different, so I cannot connect the green vac adapter for the mpg.
mark1gls said
If some one has one apart at the moment you can tell what resistor is fitted by the coloured bands on it or if you could find a wiring diagram it may say on there?
The existing resistor has blown to bits, so no chance of identifying it. Can't find any pics/info on the main site or Google !!
Resistor are 39 Ohms
I'll leave some pictures from a board, it might help somebody One day.
This is a motometer unit from a 91 mk1 cabriolet rivage with MFA, actually has a problem, a bad PNP amplifier transistor, the one in a picture with the red test multimeter lead.
See my how to in the signature link.
Briano1234 said
While you have your Water temp gauge out, you might as well re-solder the leads to the pins, doen't take long an will make sure that your water temp gauge never goes flaky.
Yes, did that and found out that my coolant level relay is kaput!
But the MFA is fixed! :-)
VW mk1 cabriolet MFA repaired - YouTube
