Cold start splutter for about 20-30 seconds!
It has a black top, emailed the guy & he said it has the Temp at 35Deg, 8secs on there, 12v 40w also same part #0280130214. yet no 043906163A #… & it has a black connector not brown - still the same item & does the same job i assume…???
the other part number 043906163A is the VW specific number that bosch would have stamped on it before sending out to VW parts
nipped in to my trustee garage as well, mentioned about the CO test & he said it would take about 1/2 hour or so… need to get it booked in… give the main man a ring tomorrow & get it in to be tested… i'll grab a vernier from work & measure the hex nut size…
http://www.ebay.co.uk/itm/THERMOSTAT-FLANGE-AUDI-100-OE-Ref-026-121-133C-/151490422710?fromMakeTrack=true
when i put the vehicle details in it says it doesn't fit??? the part number is right?
also Classic-VW got one too..
http://www.classic-vw.co.uk/mk1-golf-front-water-flange-gti-026121133c-11712-p.asp
N 0245076 - clamp, 32-50x9x0.5 - 4.47+VAT
N 10258101 - clamp, 23-35x9x0.5 - 2.49+VAT
theres a cool remote reach version for the tricky access ones, but its a little pricey iirc
Might me more useful if you just post a reply so anyone else reading this may find it useful in the future?
This is what I use.
http://www.toolstation.com/shop/p63642?table=no
like Mark says, not cheap, but well worth it, especially for the awkward locations, like the heater matrix!
Lee
2001 Zafira 1.8
2001 Zafira 1.8
make sure the head surface is clean before you refit too, if its badly corroded clean it all up best you can then fill with chemical metal and sand smooooth
What you could do is do some scrappy hunting to locate a T piece and use that to join the 2 hoses into 1 outlet. Automatic mk3 golfs are a good source for these, depending on the pipe diameter. the other option is delete the oil cooler, or use the oil cooler-pump-flange hose from a mk3 golf as they go back to a 2 outlet front flange.
Ideally use a 1.8 8v one, if you can find with an oil cooler. possibly diesels? the 2.0 8v one is slightly longer, but then again some come with a plastic fitting at the bottom so the upper hose coudl be removed and cut down to suit if you get one of those
Last edit: by rubjonny
